4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
fuel pump size 255?190
Old Sep 7, 2011 | 09:22 PM
Svtwv's Avatar
Svtwv
Default fuel pump size 255?190
Ok im having problems deciding on a pump.I've seen where alot of people run the 255 because its plenty enough pump. But can it be to much? Im running 35 lb injectors, front mount,a mild cam...would a 190 be all I need?also if you run the 255 do you have to use a adjustable fuel pressure regulator? thanks
Old Sep 8, 2011 | 12:33 AM
7_Zero's Avatar
7_Zero
It all depends on what your plans are for the car and how much hp you are wanting to make. I want to say that the TurboCoupe came with a 190LPH pump, (could be wrong) so it should be enough for your current setup, but if you have any upgrades planned for higher hp goals in the future, then you might as well spring for the 255 to start with. Yes, you will have to use an adjustable fuel pressure regulator.
Old Sep 8, 2011 | 12:02 PM
Svtwv's Avatar
Svtwv
Thanks
Old Sep 11, 2011 | 07:51 PM
mg man 75's Avatar
mg man 75
Why not go larger. Not much more and regulator will bypass what is not needed. Also the 5.0 reg fits the 2.3 rail. That is what is on mine. Maurice
Old Sep 11, 2011 | 08:47 PM
Svtwv's Avatar
Svtwv
thanks, yea Its one of those parts to just go with bigger lol also im looking at running a diff turbo an stuff now so the extra fuel can be used later on. i see you are running a c4 trans in your mustang. How do you like the automatic in it?i wanna convert to a t5, but I have thought of running a c4
Design1795
Jan 24, 2017 10:38 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
SYNY5TER
Sep 2, 2015 01:35 AM
Design1795
Aug 24, 2015 04:41 PM
