4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
93 lx 2.3l 5 lug conversion?
Old 08-26-2012, 02:41 PM
lexus6798
lexus6798's Avatar
Question 93 lx 2.3l 5 lug conversion?
Hey guys, as you can see, I am new to this site and the the Fox body platform. I am in the process of buying a 93 lx 2.3l. I have been searching around on this site and other sites trying to find information on this but I am not sure what is needed. Is there a sticky for this or are any vendors providing this conversion as a complete kit that won't break the bank?
lexus6798 is offline
Old 08-26-2012, 03:28 PM
lexus6798
lexus6798's Avatar
Come on guys, someone has to have a kit..
Old 09-01-2012, 06:50 PM
Greg Rouse
Greg Rouse's Avatar
Hey Lexus, hope you're doing well. I must honestly say that I don't have an answer, but I thought I'd at least come out here and chat it up with you. Are you saying you want to change the lugs from 4 to 5? Did you buy the car? So are you wanting to convert because you already have a 5 lug set of wheels?
Greg Rouse is offline
Old 09-02-2012, 07:47 AM
lexus6798
lexus6798's Avatar
Car is bought but I haven't gone and picked it up yet. Very good friend has it. The car has 4 lugs on it now and I would like to convert to 5 lugs. I haven't order the rims yet because I am undecided on the conversion. I really want to do 5 lugs with disc all around on an 8.8 but don't really want to spend a large sum of money. I'm willing to spend up to $1000, but don't know if it can be done for that amount. Only really for the 5 lug disc upgrade is for stopping power as I plan on having about 450-500 rwhp and very streetable. I plan on daily driving it for a whie before doing any engine mods but would like to get the rims now and not have to but different later on down the line. Car will not be a track car.
Old 09-02-2012, 11:24 AM
Greg Rouse
Greg Rouse's Avatar
Hm, okay. I see. I have never thought to upgrade to 5. But then I never really wanted to put too much power on my pony. I had a 302L once before and I went nuts driving all kind of crazy. Of course I was a lot younger then too. The car was still pretty fast, but I never had any issues (I think) with just the 4 lug system. And I had not upgraded to a disc brake system either although it had continuously crossed my mind.
I have had an issue or two with stopping ability with that drum brake system. You really have to learn how to pump and not press. I slammed on the brakes only once or twice before realizing I couldn't stop the car that way. Had to change out my tires once because I had flat spots on them from sliding to a halt.
Old 09-03-2012, 08:27 AM
lexus6798
lexus6798's Avatar
yeah, that 's what I'm trying to avoid. Like I said, the car won't be a track car but will be street driven a lot and would like to know I can stop in an emergency situation.
Old 09-04-2012, 07:31 PM
PNYXPRESS
PNYXPRESS's Avatar
I did the swap on mine for roughly $300.
I used all new edge stuff, including flexible brake lines.
Using new edge front spindles you will need to shim up the struts. You will also need to fab up an adaptor for the p/s front brake hard line to flex line. As far as rear axle pull one out of a sn95. You should be able to get all the parts out of a juck yard pretty cheap.
PNYXPRESS is offline
Old 09-05-2012, 09:22 AM
lexus6798
lexus6798's Avatar
Thanks for the information guys. You have been a lot of help...
Old 09-27-2012, 10:52 PM
milanorama
milanorama's Avatar
There is a thread on here about using ranger parts as well, that would be the cheaper route.
milanorama is offline
Old 09-28-2012, 05:59 AM
PNYXPRESS
PNYXPRESS's Avatar
only the rear axles and it wont allow disc brakes unless you can track down some SVO discs.
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
10-07-2015 07:02 PM
Quick Reply: 93 lx 2.3l 5 lug conversion?
