89 swapped 2.3t,stuck injector?engine missing..
The car idles perfect..slight quick throttle revs fast and smooth up to around 2k..even putt around the yard in it..but heavy throttle whether quick or steady it cuts out like a miss, doesnt stall or anything tho goes right back to idle..all new plugs an wires cap an rotor..ignition module also.Vane air metter problem?Stuck injector?maybe streaming an not spraying to atomize?id say possible crank shaft sensor but these cars do not have them if im not mistakin..fuel wise stock 35lb injectors,kirban adjustable fpr set at 35 psi,treperformance 255lph pump...timing is advance 8 degrees.Any help with this is greatly appreciated,the car sounds good thru the open 3 inch down pipe and im itching to let this car loose..
adamfrosceno
Aug 27, 2015 07:40 AM
Gary Ugarek
Aug 26, 2015 08:41 AM
