4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Melting Headlight Bulb '91 Mustang
Old 05-01-2015, 10:08 PM
zakkgibson
zakkgibson's Avatar
Default Melting Headlight Bulb '91 Mustang
1991 Mustang LX 2.3
so I have tried everything I can think of to fix my problem, now I'm making my first post here looking for help.
The driver side headlight on my mustang is melting, yes the bulb itself!!
Things I have done:
  1. replaced the bulb
  2. wired in a new hedlight socket/connector (it what the bulb is plugged into)
  3. rewired in yet another connetor/socket, and changed the ground to a new spot (black wire according to my haynes manual) and yes i sanded it to make sure it would have a good connection at the new place.
zakkgibson is offline
Old 05-01-2015, 10:10 PM
zakkgibson
zakkgibson's Avatar
new bulbs were also installed after each fix attempt as well.
Old 05-04-2015, 08:48 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Just to clarify, the "bulb itself" is made if glass. What is it exactly that's melting, the headlight housing?
88 orangepeel notch is offline
Old 05-04-2015, 09:30 AM
zakkgibson
zakkgibson's Avatar
No the glass itself is melting/breaking
I think I fixed the problem, the housing was full of water, I'll see if that clears it up.
Old 05-05-2015, 10:58 AM
88 orangepeel notch
Yup, water will do that to a hot bulb.
Old 05-07-2015, 07:01 AM
zakkgibson
zakkgibson's Avatar
I drilled 2 small holes in the bottom of the lens, one on each side, will this work as a temporary fix until I get new lenses?
And where are some decently priced lenses? I want to replace all of them in the front and back,
Diode Dynamics
28
05-26-2022 12:02 PM
CubanoGT
10-02-2015 10:29 AM
inyadreems
08-21-2015 09:10 AM
daytooday
08-11-2015 09:22 AM
philster0306
08-10-2015 11:33 AM
Quick Reply: Melting Headlight Bulb '91 Mustang
