Yet another gear question
No, just the gear in tranny housing and maybe the drive gear inside the trans depending on what is in there now. As I understand it there is a 4 tooth and 5 five tooth that could be insode the housing for a stick. If you have the 5 tooth then you just need to chnage the speedo gear. If you have the 4 tooth you would be wise to replace both the 4 toogh and the speedo gear. As I understnad it the four tooth won't hold up over itme.
No, the clutch has nothing to do w/ changing the gears. You'll want to get the speedo driven gear to keep your speedometer correct....I'm not sure if there is one for 4.10's.... I know there is for 3.55's.
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
