Idle Problems
Old Mar 2, 2006 | 07:28 PM
95RedStangGT's Avatar
95RedStangGT
Default Idle Problems
I changed the idle air control valve and checked for codes and none came up. I also can not find any vaccuum leaks. I can't find the reason for my car to stall and idle surge. And when i push in the clutch when shifting it surges too. Can anyone help?
Old Mar 4, 2006 | 02:59 PM
nicklec's Avatar
nicklec
Default RE: Idle Problems
I had that problem but it was from overtightning my intake bolts, seems the intake gasket started leaking an it was worse when the engine was cold and better when the engine warmed up... hope this helps.
Old Mar 5, 2006 | 11:03 PM
stanglx2002's Avatar
stanglx2002
try these few things:
clean the MAF
replace the PCV valve and screen
check the voltage on the TPS
for all these fixes click on my tech link below
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
