possible buy? claims crazy time i think
I called a guy just wondering what he was asking because he has almost the same set up as me and he told me that with the following mods he was running a low 10????
1991 lx notch
full suspension:
connectors
solid control arms
Aluminum drive shaft
3.73 gear
Steeda rear sway
50/50 lake woods
Qa1 k-member
arms and coilovers with 70/30 lakwoods
No front sway
Caster camber plates
Tire is mickeys e/t all around on welds 10.5 rear and 4 inch front
Motor:
306 stock bottom end
Edelbrock rpm heads and intake
1.7 rr
Built heads
nitrious plate with 175 shot
holly 650 4 barrel
electric fuel pump
bbk long tubs h pipe flowmaster mufflers
t-5 trans with a shifter i dont remember which
msd
alumunum radiator with electric fans
What do you think is this right?
1991 lx notch
full suspension:
connectors
solid control arms
3.73 gear
Steeda rear sway
50/50 lake woods
Qa1 k-member
No front sway
Motor:
1.7 rr
Built heads
holly 650 4 barrel
electric fuel pump
msd
RE: possible buy? claims crazy time i think
ORIGINAL: JD1969
Depending on how much the car weighs I could see it running 10's maybe not low 10's though. Ask to see proof.
well my friend has a 331 stroker carbed car with c-4 that runs 10.8's on motor"354rwhp" and 9.9's on 75 shot"415rwhp" car and driver 2950lbs
yes its possible, if it can hook
