What are the chances?
RE: What are the chances?
ORIGINAL: ckyguy68
this may sound stupid, but what if you gas was low enough for you to lose fuel pressure when taking turns. i know the tank has baffles but it could be a possibility.
ORIGINAL: FiveLiterRiceEater
if it backfired through your throttle body your timing is probably off, are you positive your distributor isnt 180 off?
ORIGINAL: PRO50SC
W/ all that new gear, the ecm may be having a brain fart. It's not used to running at the capacity it is now. You may have to have chip burned for it.
ORIGINAL: FullAuto
Well I don't think you're beyond the computer's limits. I made over 600rwhp with a stock A9P with no chip.
no chip?? please explain[&:] i should be well over 700whp (pump gas) on a mustang dyno when i tune for methanol w/ a stock computer...but i certainly have a chip (sct w/ 4 programs).
1990 i woud check for vacuum leaks, tps voltage, and iac
btw there are cars making over 1000whp on the stock comp. with some sort of tuner
09-17-2015 07:57 PM
09-17-2015 07:32 PM
