Gas Leak?
Old Mar 22, 2006 | 06:14 PM
fordracing1122's Avatar
fordracing1122
Default Gas Leak?
Every time i get in my car i smell gas, when i am looking under the hood it looks wet behind the upper intake manifold...
Is there a common gas leak in this area, maybe the fuel lines?
Thanks
Old Mar 22, 2006 | 06:19 PM
Tims 88GT's Avatar
Tims 88GT
Default RE: Gas Leak?
behind the upper intake between the fire wall? have you started it and looked, 39psi should show up
Old Mar 22, 2006 | 06:38 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Not a common thing to leak. Start the car and look at the injectors real good. One could be leaking.
Old Mar 22, 2006 | 06:57 PM
1fastzook's Avatar
1fastzook
It might be the rubber hose that connects the fuel rails together if your fuel rails are stock.
Old Mar 22, 2006 | 07:11 PM
Tims 88GT's Avatar
Tims 88GT
^^ thats what i was thinking. but if its running 39psi man thats going to make it show up.
Old Mar 22, 2006 | 10:22 PM
fordracing1122
The fuel check valve is between the fire wall and the upper intake?
It kinda looks like it might be the rubber hose...
Thanks for the help!
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
Sixer4Life
Oct 12, 2015 04:26 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
