speedometer gear ?
Old Apr 1, 2006 | 04:19 AM
biglg's Avatar
biglg
Default RE: speedometer gear ?
So I need a 22 tooth and a 6 tooth. SHI*! My car is at the shop and ready for pick up tomorrow for my gear change. Dam, i was sure all I needed was a 20 tooth. I was told that by about 30 people. You are talking about an 89 5 spd? GRRRR
Old Apr 1, 2006 | 04:26 AM
ikeybmg's Avatar
ikeybmg
20 tooth isnt close for 3:73. 6 tooth and 22 tooth is what you need. you can only get close with a 7 and 23.
Old Apr 1, 2006 | 04:28 AM
Liquid_02's Avatar
Liquid_02
That's just the best route to go is all I'm saying, it's a lot of work to replace the drive gear, probably cost $100 in labour. You need to know what gear you have in your tranny to start with, either the yellow 7-tooth or the green 8-tooth
Just think about it.
Stock rear-end gears 2.73
Stock speedo drive gear 7
Stock speed driven gear 19
19 / 7 = 2.71 (the rear-end ratio)
NOW
23 / 7 = 3.29 (not even good enough for 3.55's, but it's all you can get)
Old Apr 1, 2006 | 05:42 AM
gspfunk's Avatar
gspfunk
ORIGINAL: biglg
GPSFUNK,
What year is your car? I have an 89 and I just had 3:55's put in, I was told my a dozen people to get a 20 tooth? I have stock wheels, tires, etc. Stock car, 3:55 gears, 5 spd!
I have a 90. I think 89 and lower the 23 tooth is for 4.10's..... There was a chart on D&D performance's website.
Old Apr 1, 2006 | 10:01 AM
biglg's Avatar
biglg
Here ya go guys. THis is also from 50resto.com, latemodelrestoration.com.
Speedometer Gear Help Guide
Ring & Pinion Speedo Gear Part Number
1983-89 Mustang Manual 5-Speed
3.08 18 Tooth LRS-17271H
3.27 19 Tooth LRS-17271A
3.55 20 Tooth LRS-17271B
3.73 21 Tooth LRS-17271C
4.10 23 Tooth LRS-17271D
1990-93 Mustang Manual 5-Speed
3.08 20 Tooth LRS-17271B
3.27 21 Tooth LRS-17271C
3.55 23 Tooth LRS-17271D
1984-89 Mustang Automatic AOD
3.27 19 Tooth LRS-17271E
3.55 20 Tooth LRS-17271F
3.73 21 Tooth LRS-17271G
4.10 23 Tooth LRS-17271J
1990-93 Mustang Automatic AOD
2.73 19 Tooth LRS-17271E
3.08 20 Tooth LRS-17271F
3.27 21 Tooth LRS-17271G
3.55 23 Tooth LRS-17271J
1996-98 Mustang Cobra Manual 5-Speed
1994-98 Mustang Manual 5-Speed
Except 1996-98 Cobra
1994-98 Mustang Automatic AOD
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
