Subframe Connectors WELD IN
#41
RE: Subframe Connectors WELD IN
89 GT RED those connecters should be fine if they fit good. since you have a convertible you may want to consider FULL LENGTH sub frame connecters. just make sure who ever welds them in knows how to do it . it is good to put the car on a DRIVE ON lift with hood,doors, trunk shut , top up with windows up.
#42
Cool THX Crazyhorse. So do you think that these might not be good enough for a vert? I got a full time welder down the street, sounds like he will do it for cheap. Should i hold off on these and get full length? I was told by Godspeed that it shoud be adequate but i definietly wanna make sure.
#43
those should be good . if you are planning on adding a s/c , n/o , to create huge hp then you would need full length. they just stiffen it up a little more . you could also add a strut tower brace, they are very reasonable & help stiffen up the front end some. good luck.
jwog666
12-27-2021 08:09 PM
09-17-2015 07:57 PM
09-01-2015 08:16 PM
