Wiring harness question
Whats going on yeah i was looking though the summit racing catalog i looking at my enigne and i would really like to clean up my all the wires in my engine bay also because when i was taking apart my dad and i broke a few of the plastic clips for the fuel injectors and i heated them up and everything. So i was just wondering if anyone knew which brands were good and what kind of wiring harness i was looking for.if i do get a new harness there is no cutting or anything i should just have to unplug somin and plug the new harness in?Thank Bryan
RE: Wiring harness question
no, the harness would have to be replaced if you plan to do this with no cutting/splicing. There isn't just a separate harness for the injectors... You could still just cut that section out of another wiring harness, and basically, coming off all the injectors there will be a string of wires heading toward the rear of the car, and then fusing into thebig fat strand of cables along the firewall... you would basically want to cut it off around that point, install it onto your motor, then splice the wires near the firewall
if you just broke a few tabs on injector connectors, run to a junkyard and cut a few out of some ford on the lot, the connectors are all the same. if you clean up the engine bay, hide the excess wires by routing them through the fenderwells and such, do a search on hiding wires, youll see what i mean, im in the process of doing it myself, once you dive into it its pretty easy.
