Hydraulic Roller vs. Solid Roller Cam?
Old 04-02-2006, 05:20 PM
kl92gt
kl92gt's Avatar
Default Hydraulic Roller vs. Solid Roller Cam?
what is the difference between a hydraulic roller cam and a solid roller cam? is there a difference in power between the 2? im building a 306 with afr 185 holley systemax intake and a custom cam should i stay with hydraulic roller or switch to solid roller?
i need some help guys
kl92gt is offline
Old 04-02-2006, 07:43 PM
kl92gt
kl92gt's Avatar
Default RE: Hydraulic Roller vs. Solid Roller Cam?
can anyone help me out
kl92gt is offline
Old 04-02-2006, 07:45 PM
Tims 88GT
Tims 88GT's Avatar
solid roller means dont miss your shift because it will go kaboom if you get to many r's
Tims 88GT is offline
Old 04-02-2006, 09:04 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
actually Tim a solid roller will rev higher, but your right about less cushion on a miss shift (more likley to bend a push rod or break a rocker stud). Generally speaking a solid is good for high rpm, high hp applicatons. With a solid there is usually more wear and tear and they usuall only come in pretty agressive profiles. IMO unless this is a real track or weekend car, that already has good heads and big gears, just stick with a hyd. roller.
JD1969 is offline
Old 04-02-2006, 09:43 PM
kl92gt
kl92gt's Avatar
yea its going to be pretty much my daily driver so i think ill stay with a hyd thanks a lot
kl92gt is offline
Old 04-02-2006, 09:46 PM
Twister
Twister's Avatar
the main difference is about 1000 rpms...unless you plan to zing it like a honda, do hydrolic
Twister is offline
Old 04-02-2006, 09:48 PM
Albizo66
Albizo66's Avatar
does a solid roller require solid lifters? is that the whole point behind the "solid" name?
Albizo66 is offline
Old 04-02-2006, 10:35 PM
JD1969
JD1969's Avatar
ORIGINAL: Albizo66
Yes
JD1969 is offline
Old 04-02-2006, 10:37 PM
grabbem88
grabbem88's Avatar
honda's use solid cams?
ORIGINAL: Twister
grabbem88 is offline
Old 04-02-2006, 10:38 PM
Albizo66
Albizo66's Avatar
ORIGINAL: JD1969
ORIGINAL: Albizo66
Yes
thought so, thanks JD
Albizo66 is offline
Quick Reply: Hydraulic Roller vs. Solid Roller Cam?
