Rebuilding engine..
RE: Rebuilding engine..
since when is it a good idea to bore a stock 302 .60 over??? people usually get it bored over during the rebuild to 306, just for the extra cubes and probably a few horses. might as well while your in there right? you dont have to bore, and if you dont trust your mechanics to bore your block then i sure as hell hope you dont plan on letting them touch the engine during the rebuild. e303 is a decent cam to go. i hope to go something bigger in the future.
DAMN! well maybe peolpe are too lazy to post it then, unfortanately that info does me no good so................. i could care less j/k god daam im tired goin to bed. im out[sm=burnout.gif]
ORIGINAL: zkit18
How can you tell if you need to bore it? I have a bit over 150K on my engine and I would like to rebuild the engine before I leave the island. I am gonna get the forged piston kit from summit but I don't want to bore it if I don't have to. I've never done it and I don't trust any mechanics here (to do it right or to not overcharge me). Also what else should I get when I the kit to add a little more reliability and hp without raising the gas milage (gas is between $2.20 - $2.50 for regular here)? Cam? Timing gears? If so, what type? I have new headers, cold air intake, and I am going to upgrade to 130 amp alt as soon as I can figure out the wiring. Thanks.
cylinder bore - 4.000" - 4.0048"
out-of-round limit - 0.0015"
out-of-round service limit - 0.005"
taper service limit - 0.010"
I would ask around and find a good automotive machine shop in the area and talk to them about what you want to do. you would need some professional machining work done anyway for a good rebuild so this is what I would do first. they have all the proper tools to measure the block and crank for wear and can tell you exactly what needs to be done to restore the block and what size pistons and bearings will be needed after the machining is done so you can order the right size parts in the rebuild kit. I would not bore the block more than 0.030" in any event as the 5.0 cylinder walls are kinda thin to begin with and 30 over is a stock rebuild piston size you can easily buy in a kit.
ORIGINAL: 91hatchgt
444/444 276/267 @ .050 with an Overlap of 39 I know my stuff aight!
