4:10 gears
RE: 4:10 gears
So I figured out what a different gear ratio will do to the engine's rpm.. You take the differance in ratio of the new gear and the old one: 4.10 (new) and 3.08 (my old one) 4.10 - 3.08 = 1.02. Then you take that (1.02) and devide it by the original gear ratio (3.08). 1.02 / 3.08 = about .33 Take your target rpm (to see how much it will jump with the new gear ratio) say 2000 rpm and multiply it by the % it will jump (.33) 2000 x .33 = 660 you add it to your target and you get your new 2660. it works for any rpm, as your rpm will cange the higher it gets with a new gear ratio.
.33% is the how much change you'll see in rpm.
4.10 - 3.08 = 1.02
1.02 / 3.08 = .33
(target rpm) x .33 = new rpm
make sense?
4.10 - 3.08 = 1.02
1.02 / 3.08 = .33
make sense?
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
