oil filter 347 stroker
RE: oil filter 347 stroker
no. the cracked block was on another car. this motor is pretty fresh about 3000 miles max on it.just didn't know if these superchargers seeing that they are oil fed would miss color or do that to the oil while in the block like that.I have a saleen s/c also but its rootstyle unlike the vortech.this car is a 95 cobra 619 rwtq.suspect is the headgasket but that typically affects hrsp.and driving and it runs better than ever .just got it back from shop 2 days ago after they did posi install,rollcage,race seats,rad.fan contol switch and oil change.then noticed the leak which lead too the oil look .at first i thought it was the filter but changed it and the look was in the new filter too.?
Well if i was you. one morning craw under the car and crack the plug a lil and see if you have a milky white color/ green/water come out. just crack it a lil so it drips out really slow. that will tell you if you have a problem. if nothing comes out dont worry about it.
