Alternator...
RE: Alternator...
35 amps additional output power. you don't need a bigger one unless you have a big load of additional stereo stuff using up a lot of power. more amps is just more load on the motor and unless you really need it, stay with the 95 amp unit.
RE: Alternator...
Its not really a matter of more amps its when those amps start to come in and at what rpm.
Usually the reason (NOT ONLY THE EXTRA AMPS) that the aftermarket alternators are so good is because they put out more power earlier.Thats one reason that when you run under drives that it doesnt really effect the output.
capri debris
05-02-2008 06:39 AM
