setup questions
Old Apr 14, 2006 | 11:27 PM
91lxstang's Avatar
91lxstang
Default setup questions
what do you guys think about this setup for a daily driver?
73mm maf
24lb injectors
70mm tb
better radiator
ud pullies/ ac delete
bbk or mac headers
bbk of road h pipe
magnaflow magnapacks dumped
track heat intake
tfs1 cam
afr 165 emmisions legal heads
bigger fuel pump
king cobra clutch
new t5 tranny with steeda triax
aluminum drive shaft
3.73 gears
eibach sportline springs
245/45/17 on front
275/40/17 on back
just street tires
and better ignition system
..... what do you guys think i can run if i drive good? just curious
Old Apr 14, 2006 | 11:44 PM
91lxstang's Avatar
91lxstang
Default RE: setup questions
anyone?
Old Apr 14, 2006 | 11:48 PM
collincastaneda's Avatar
collincastaneda
I'm guessing somewhere around 13.5 <.
What do you think about those heads? How much were then after shipping and all that bs?
Old Apr 14, 2006 | 11:54 PM
91lxstang's Avatar
91lxstang
i dont have that but thats what i plan on buying this summer
Old Apr 14, 2006 | 11:55 PM
91lxstang's Avatar
91lxstang
really? only a 13.5? that should be around 330 to the wheels i think ....... i thought it would b in the high 12's
Old Apr 15, 2006 | 12:00 AM
collincastaneda
13.5 < = or less.
Old Apr 15, 2006 | 01:30 PM
gspfunk's Avatar
gspfunk
My guess is ~310 to the wheels and high to (maybe) mid 12's. Depends on the weight of your car and suspension/chassis.
Also, don't waste your money on another t5. Get a beefier Tremec or Gforce. You'll want something that can handle more power.
Old Apr 15, 2006 | 01:36 PM
93BlackNotch's Avatar
93BlackNotch
It should go atleast mid 12's with that set up... I'd do the Street heat instead of the Track heat... Everything else looks decent... Crane Hi-6 ignitions are good and of course MSD 6al, but alot of MSD's have been ****ting out on people.... do some research before you buy each item... Good luck
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
treesloth
Sep 28, 2015 07:03 AM
