Carb issues...
Old 04-18-2006, 10:43 PM
  #21
meiguoren33
meiguoren33's Avatar
Default RE: Carb issues...
Any luck?
meiguoren33 is offline
Old 04-18-2006, 11:41 PM
  #22
tinman
tinman's Avatar
Replace filter.
I think that needle/seat may be the problem........
tinman is offline
Old 04-18-2006, 11:42 PM
  #23
tinman
tinman's Avatar
Jetting won't really matter.......
tinman is offline
Old 04-19-2006, 12:00 AM
  #24
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
I worked late tonight so I didn't get to mess with it.
The needle & seat are new from the Holley kit.
Grimace5.0 is offline
Old 04-19-2006, 12:14 AM
  #25
Tims 88GT
Tims 88GT's Avatar
I did not read the whole post, but it sounds like its rich. Did u change the jets?
Tims 88GT is offline
Old 04-19-2006, 12:24 AM
  #26
meiguoren33
Jets don't come into play when idling. Only the idle mix screws, when you hit the gas the transition slots give it a little gas until the air blows past the jets. Of course the accel pumps also make up the lag between opening the flies until the air can pick up gas from the jets.
But, since there are two power valves, the base gasket is not blocking the orifices where the power valves recieve the vacuum signal right?
Old 04-19-2006, 01:15 AM
  #27
Joel5.0
Joel5.0's Avatar
Jay;
I think this article (if you don't have it already) might be of help. GL
Joel5.0 is offline
Old 04-19-2006, 09:30 AM
  #28
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
Hmmm... thats a good question. The prev owner had a plug in the rear. When I rebuilt it I put the PV's in it.
Joel, thanks for the link, I was looking on there last night.
I'll mess with it tonight and see what I can figure out.
Old 04-19-2006, 06:04 PM
  #29
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
Alright, I adjusted the secondary throttle blade. It now appears ( from the top ) that it is completely under the transition slot. I re-set the idle speed ( primary throttle blade position ) and tried the air mix screws. Now when I turn them in the engine speeds up. I thought it was supposed to die when you turn them in?
Another question/opinion..
When I rebuilt it I put a power valve in the rear. From the factory BG says it's plugged. Maybe I should plug it and see what happens?
Typically when you remove the power valve you jet up 4 or 5 sizes. I have 74 and 78 jets now, from BG they are 71 and 79. Thoughts?
Old 04-19-2006, 06:25 PM
  #30
Tims 88GT
Tims 88GT's Avatar
dont know what to say. i know nothing about carbs but ill ask my dad when he gets home. He might know something.
Quick Reply: Carb issues...
