Recalibration Speedo?
I've had 3.55 gears for awhile now and I'm finally going to recalibrate the speedo. I have a 94 GT and isn't there a gear I need to get to put in the trans or something? I have a World Class T-5? A part number would be great.
Thanks
Thanks
RE: Recalibration Speedo?
not hard at all. just find the speedo cable where it enters the trans and there's usually one or two bolts at most holding the cover in place. pull the assembly out, replace the old gear with the new one, and reverse the process and you're done. use a drain pan under the trans as you might leak some gear oil when you do this and put the oil back in when you're done. piece of cake! when I did my AOD, I jacked up the car on the side with the gear hole up so the oil ran away from the hole and didn't spill a drop of ATF.
