Some input please
I think i finally found the Fox i want, it needs work tohught, interior which the guy says will come withthe car not installed....
It was taken out becuase of a water leak coming form the firewall and drivers side front fender, ho much ould that cost to fix? is it a simple fix or somthing i should get a body guy to do?
is it the heater core? take a hose to it and see if thats what it is pour it around the windshield and thru the cowl opening etc look for the leak its probably ther heate core thought and thats costly unless u do it ur self!
it could be your heater core. if so you have to rip out your dash to fix it or you can just bypass the leak by looping it i believe. but if its just regular water such as rain water or when you hit a puddle or whatever find the leak and just put some silicone down, not to much just spread it with your finger or just strip where the leak is down to the metal and slap some jb weld to it unless you can weld witch would be hard because the gauge of the steel is real small.
