quoted for gears
#22
RE: quoted for gears
ORIGINAL: Black Snake
Its not hard to do yourself, just check your clearances and be sure to replace all your bears. Be sure to shim it right.
#23
Like? You prolly need an impact wrench, and basic handtools.
You dont have to pull the bearing off the other pinion. Go to your local hardware store and get a pinion bearing from them its usually a stocking iteam.
And I had somone press it on for me.
#24
need to be careful on self install.
you will a micrometer to measure backlash also.
I was quoted $500 installed with speedo recalibrated too.
somethings are worth have a pro do.
dont forget your speedo if you're doing it yourself.
#26
yes, you need a micrometer with magnetic base, they're
not that expensive.
Horse Power TV had a spot on changing gears, didnt look that hard
"if you knew what you were doing".
It has to be shimmed correctly and backlash has to be set right.
If you could find some good step by step instructions you should be able
to do it yourself.
again, dont know what it takes to calibrate the speedo.
not that expensive.
to do it yourself.
ORIGINAL: Stevens91gt
well it's cuz ive read on here about others doing the
install by themselves and they said they needed special tools
#29
ever run your own business? you have to cover all kinds
of overhead plus make money.
phone bill
payroll
electricity
rent
tools
supplies
insurance
on and on......
my $500 quote was complete....., gears, seals, bearings, new speedo gear, fluid, labor.........
more to it than just buying some $160 gears and dropp'n them in.
phone bill
payroll
electricity
rent
tools
supplies
insurance
on and on......
ORIGINAL: ddeaton66
so $300-$400 for labor is normal.....I need to open a shop around here.....
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
