vert will not convert
Old Apr 21, 2006 | 10:25 AM
slo5.0's Avatar
slo5.0
Default vert will not convert
occasionally when i go to put the top down the switch makes a clicking sound but the motor doesn't activate. do the brushes in the motor need replaced -- or what?
Old Apr 21, 2006 | 12:59 PM
Jstang's Avatar
Jstang
Default RE: vert will not convert
Check the wiring on the motor to see if its loose
Old Apr 21, 2006 | 02:46 PM
slo5.0's Avatar
slo5.0
do i go thru the well or the trunk to get to the motor?
Old Apr 21, 2006 | 05:25 PM
BigDaddyJames's Avatar
BigDaddyJames
Yeah go through the trunk, lift the bag that the roof sits in and the motor is under there. I have the same problem with mine, clicking and nothing else. Sometimes the motor works though. It's wierd.
Old Apr 21, 2006 | 06:42 PM
Mustang95's Avatar
Mustang95
Make sure the mortor has oil in it...could be the problem...
Old Apr 21, 2006 | 06:59 PM
BigDaddyJames
I was thinking that, I had a 68 Camaro and the roof motor didn't work till I filled it. And given the history of my 90 Vert I wouldn't be surprised if the motor was empty. Looks like I have some work to do this weekend.
92hatchLX's Avatar
92hatchLX
Which way are you pushing the convertable switch? towards you or away from you?
Old Apr 21, 2006 | 07:57 PM
BigDaddyJames
Both ways....
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
