caster camber ?
RE: caster camber ?
u need aftermarket cc plates when u lower a car. what all gets shorter???? the springs and the ride height. what does not change??? the shock does not get shotter. a shock is ment to have a slight load on it, but when u lower the car the load becomes to much. so you have cc plates that have a spacer between the shock tower so u can still use the stock shock. Also when u lower the car all the suspension changes, so u need to get an elignment. but the stock plates do not have the right amount of adjustment to fix the +camber you have cause with lowering the car.
