EFI to Carb conversion?
Old Apr 25, 2006 | 02:34 AM
  #21
meiguoren33's Avatar
meiguoren33
Default RE: EFI to Carb conversion?
88 vert, was that the procomp dizzy with the cheby style cap? Did it come with the module and coil hooked up? If so, how do you like it?
Old Apr 25, 2006 | 02:59 AM
  #22
88blackCONvert's Avatar
88blackCONvert
ORIGINAL: meiguoren33
I do believe it is. I remember something like bulldog in the description, but im pretty sure it's procomp. It came with everything in the picture below (the coil was red on mine though) for $90 shipped i think. I put the steel gear (included) on by hand, and can take it off pretty easy, but the guy said it's designed that way??? it does work nice though with my msd6al box, and looks great for the price. Only thing i didn't like about it is that its HEI design, and is pretty big. There's some duraspark style ones for same price, but it looked like it had a big foot or something at the base that would cause some clearance problems, so i went with this one.
Deffinately worth it, but i've only had it a month or so, so i can't tell you how durable it is, but for the price you can't beat it.
[IMG]local://upfiles/32278/22A4DD0E16AC41A8AF488D897E3B3BC0.jpg[/IMG]
[IMG]local://upfiles/32278/4E2C7A66FEB444DCBAD69F4E1744A75C.jpg[/IMG]
Old Apr 25, 2006 | 03:08 AM
  #23
88blackCONvert
Ganassi Racing to do it his name is Ben Coward
Hey Crump, where's this guys shop at? and how much would he charge the avg joe for a dyno/tune? Been lookin for a local guy (not too hard till i get everything fixed), but would be some nice info to have.
Old Apr 25, 2006 | 04:44 PM
  #24
OJMiles's Avatar
OJMiles
Ok, so i have a 5.0 HO motor i'm going to be doing a carb swap... I was thinking of going with this distributor:
http://store.summitracing.com/partde...5&autoview=sku
And changing out the gear to steel... is that dizzy compatible with my setup with a Blaster 2 or 3 coil and MSD 6AL ?
Thanks... OJM/Paramedic
Old Apr 25, 2006 | 08:40 PM
  #25
Crump_4's Avatar
Crump_4
The shop is here in rock hill on main street. D&D Performance Machine is the name of the shop. Ben is someone we ran across at P1 Performance in charlotte. At D&D there is a depac 2000HP engine dyno. I went to school with the owner. not sure what his hourly price is though.... I do know that for the whole day he charges about 500.00 and that includes putting the motor on the dyno and running/tunning what you have. He is however looking into getting chasis dyno. Ben is going to charge me 300.00 to do mine and I dont have to pay for the use of the dyno.
ORIGINAL: 88blackCONvert
Old Apr 25, 2006 | 09:37 PM
  #26
tinman's Avatar
tinman
That fuel pump relay is no sweat.
I've used several 'PAINLESS WIRING' ones with Holley pumps. They cost about $27 but the wires are all labeled as to where to go with each one........
I'd solder/shrink tube everything......
Old Apr 25, 2006 | 09:39 PM
  #27
Crump_4's Avatar
Crump_4
where do I pick up a painless wiring relay
ORIGINAL: tinman
Old Apr 25, 2006 | 10:54 PM
  #28
88blackCONvert
Thanx for the info on D&D crump. I'ma have to check em out. As for the relay there's only one wire to hook up to use your old relay that you already have. It was kinda hard for me to find since my chiltons manual had 2 of the same pages, and was missing the page that i needed. It wasn't hard though, just ran some power to the pink/black wire into the relay, and just extended the wires from my original fuel pump to my new one (like Fletch said).
Old Apr 25, 2006 | 10:58 PM
  #29
88blackCONvert
ORIGINAL: OJMiles
OJ, you shouldn't have a problem hooking that up to your 6AL, and it will be a good dizzy (msd makes some nice shiz), but i didn't want to pay that price, so i hit up my ol' pal EBAy, and found a few cheap ones. Im super happy with the one i got for almost 1/3 of the price of an MSD.
Old Apr 25, 2006 | 11:04 PM
  #30
OJMiles's Avatar
OJMiles
I'll be more than happy to purchase a non MSD if i can find one for a carb engine, non-HEI, with vacuum advance, steel gear, but so far i havent found a good alternative, and i wanted something a little nicer than stock. Any suggestions?
-- OJM
