GT40 Heads
Old 04-27-2006, 02:31 AM
ttoppedaerocoupe
ttoppedaerocoupe's Avatar
Default GT40 Heads
Anything noteworthy about swapping GT40P heads? I think it may be in my near future, but just want to get any surprises out of the way before I drop some $$$ on them. Anything to look for in particular? any years better than others??
alex m
ttoppedaerocoupe is offline
Old 04-27-2006, 02:51 AM
Twister
Twister's Avatar
Default RE: GT40 Heads
you will need special headers
Twister is offline
Old 04-27-2006, 03:46 AM
ttoppedaerocoupe
what kind of different headers, obv for clearance issues, but what would work?
alex
Old 04-27-2006, 04:06 AM
Liquid_02
Liquid_02's Avatar
You'd get just as much power by porting your stock heads, and then you get to keep your headers, so if you decide to upgrade to alluminum in the future, you didn't waste money on a set of headers. My .02
Liquid_02 is offline
Old 04-27-2006, 04:37 AM
I3atR!ce
I3atR!ce's Avatar
http://cgi.ebay.com/ebaymotors/MUSTA...spagenameZWDVW
here ya go... heads and headers all in one. get them ported (http://www.hunterstyle.com/thumper/) and valve job and such.
I3atR!ce is offline
Old 04-27-2006, 04:53 AM
ttoppedaerocoupe
current high bidder, thank you very much.
Old 04-27-2006, 04:58 AM
Liquid_02
Liquid_02's Avatar
You bidded on those without even knowing how many miles are on them? I would never bid on a used set of heads (heads that I haven't seen that is), they were taken off for a reason, let it be a blown up motor, or the heads are bitched, it all affects the heads, from oiling if the engine ran out of oil to cooling if they were over-heated. And those don't look too hot, looks like the mating surface has started to rust so you're for sure going to have to re-surface them :\ Just a warning before you bid anymore...
Old 04-27-2006, 12:22 PM
Twister
Twister's Avatar
ORIGINAL: ttoppedaerocoupe
alex
it has to do with the angle of the spark plug. New FRPP headers will work
Twister is offline
Old 04-27-2006, 02:52 PM
philthy89fifty
philthy89fifty's Avatar
also gt40p heads will have to be drilled for smog.
philthy89fifty is offline
Old 04-27-2006, 05:15 PM
gspfunk
gspfunk's Avatar
the P heads are good if you get them cheap. If you have $1k, then get used AFR's or new/used TW's. Either will flow better and give you a lot more power than any GT40's.
gspfunk is offline
Quick Reply: GT40 Heads
