dynamat
Old May 1, 2006 | 09:59 PM
odogg88's Avatar
odogg88
Default dynamat
i know it works for stereos, but will it keep enging and road noise out?
Old May 1, 2006 | 10:39 PM
Black Snake's Avatar
Black Snake
Default RE: dynamat
Yes, but it make you already heavy vert into a boat.
Dynomat weighs alot, your going to add about 45 lbs to the floor by doing this.
Old May 1, 2006 | 11:09 PM
odogg88's Avatar
odogg88
Default RE: dynamat
thats not a concern, already taken off 200+ lbs off the car.
Old May 2, 2006 | 02:50 PM
jonnyslick's Avatar
jonnyslick
Default RE: dynamat
^ why remove weight ... then add more back ... unless the weight you're adding back is in the means of a performance mod (such as a roll bar, superchager, etc.) then why remove things that are heavy and put new things back in?
i say ...
if your removing weight ... get rid of as much crap you don't need; at this point it's gonna' be for performance so who cares how loud/uncomfortable it is.
if you want a quite/comfortable car and don't care about weight ... then don't worry about removing any "excess" weight in the first place and add all the dynomat you need.
Old May 2, 2006 | 04:48 PM
88BlueGT's Avatar
88BlueGT
Default RE: dynamat
Why cant he care about weight but not want a super loud car? If he kept the weight as stock plus 40lbs of dynamat than he would be 40+ over stock.. RIGHT? But now that he reduced his weight by a few hundred hes still under stock and gets what he wants... which is a light car thats not loud as hell.
Yes, dynamat will help with the noise.
Old May 2, 2006 | 04:54 PM
gspfunk's Avatar
gspfunk
Default RE: dynamat
If you're going to replace your carpet anytime soon, just get the mass backed carpet. You shouldn't need dynomat w/ it...it's supposed to have a similar effect.
Old May 2, 2006 | 04:55 PM
88BlueGT's Avatar
88BlueGT
Default RE: dynamat
^^ True.
Old May 2, 2006 | 06:14 PM
odogg88's Avatar
odogg88
Default RE: dynamat
ORIGINAL: jonnyslick
i say ...
well, all the weight that i removed was function, not for weight reduction, k member/coil over kit, took out a/c smog, went to a manual rack, all this added performance not just weight reduction, among other things, i still have a full interior, not to be a dick but the thread was will it keep noise out, not will it weigh down my car!!!
69FB
Aug 18, 2015 08:50 PM
nicarc369
Jul 19, 2011 04:52 PM
06stangGT
Aug 6, 2007 01:09 PM
richmod
May 3, 2007 12:01 AM
Azure
15
Jan 24, 2007 12:46 AM
