Ring gear and pinion install.
I picked up a 3.73 today and need to find out how the numbers stamped on the end of the pinion help set up the gear. Its not like what I am use to seeing in a sense. The way Dodge's set up is 0 , +1 , -1 and so on. If its 0 you use same size shim on the pinion. If its +1 then you subtract .001 from shim, and the opposite for -1. The numbers on this pinion are not anywhere close to this so i am cornfused " that is right I said coRnfused ". And please dont ask what the #'s are like a dumba** I left the gear set at the shop so I cant answer correctly. Looking for a how-to site i guess would be good to find if someone has one to share. Yes i googled it and didnt turn up anything worthy. Thanks in advance[&:]
RE: Ring gear and pinion install.
ORIGINAL: mcfomco
http://www.corral.net/tech/drivetrain/gears.html and
http://www.angelfire.com/theforce/5o...5ohtech001.htm
KingRando
10-02-2015 08:06 AM
