View Poll Results: A poll
Voters: 8. You may not vote on this poll
ok, poll... which exhaust sizes are better for my motor?
RE: ok, poll... which exhaust sizes are better for my motor?
3" system won't help you unless you have bigger primary tubes on the headers
I would do the 2.5 and have the 3" tail pipes
the exhaust is tuneable to change the rpm range so bigger isn't always better..I can tune a set of header with 2.5 that will just kill a 3" exhaust...this is done with lengthing the collector tubes on a long tube headers....
if using a 3" exhaust
2" primary tube headers would be needed and you bottom end would suffer unless a tubro or S/C is added inorder to benifit the engine would needs to be able to spin 7-7500 freely so your heads will be the restriction...and with 3" exhaust cam shaft overlap needs to have some attention
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
mustangsrforever!!!
08-06-2015 12:04 PM
