Need AFR 165 HELP Please!
Old May 6, 2006 | 12:45 AM
OnyxCobra's Avatar
OnyxCobra
Default Need AFR 165 HELP Please!
I was all ready to order my heads tonight and ran into a few problems. I talked to AFR and they said since their valve springs are stronger than the stock ones I would need to run hardened pushrods even with the pedestal mount heads, even though it says on their site hardened pushrods are only necessary for the stud mount rocker heads. He said I need to measure to see what length pushrod i need, how would i go about doing this? I thought this was going to be fairly simple and now i am so confused, please help!
Old May 6, 2006 | 12:51 AM
grabbem88's Avatar
grabbem88
Default RE: Need AFR 165 HELP Please!
calm down....if you get hardened get trickflows...stock length....i ran stockers in my 185's for a while till i founf a set at a swap meat for $25 bucks brand new...so you are ok with what you decide
Old May 6, 2006 | 12:53 AM
OnyxCobra's Avatar
OnyxCobra
how can i be sure they're the correct length? I dont even know what size i need...
Old May 6, 2006 | 12:54 AM
grabbem88's Avatar
grabbem88
6.25 is stock but most go 6.30-6.6.35's for less shims.....
Old May 6, 2006 | 12:56 AM
OnyxCobra's Avatar
OnyxCobra
less shims? even with pedestal mount heads?
Old May 6, 2006 | 12:59 AM
grabbem88's Avatar
grabbem88
well i did mine that way so i could get the right installed highth on new springs...sorry..
mine are pedestal mount also..hate there springs.
Old May 6, 2006 | 01:01 AM
OnyxCobra's Avatar
OnyxCobra
sorry man i think i lost you. There is more to know about this than i thought...
Old May 6, 2006 | 01:03 AM
grabbem88's Avatar
grabbem88
do what i did...they worked fine...they advise hardened pushrods just to save there butt
on liability
ORIGINAL: OnyxCobra
Old May 6, 2006 | 01:04 AM
grabbem88's Avatar
grabbem88
oh and there valve springs arn't that much stronger than stock
Old May 6, 2006 | 01:13 AM
OnyxCobra's Avatar
OnyxCobra
they said the stock arent even 100, the standard springs are 120 and the upgraded ones (which i was gonna get) are 150... so they're a good deal stronger. Dont you have the 185s?
