door panel removal
Sorry I don't have a picture for you.
You need a Trim Pad Remover. I used it to take off my door panal when I change my door handles.
You should be able to buy 1 from any store that sells tools.
ex Snap On, Sears,
http://buy1.snapon.com/catalog/parts...&group_id=5528
ex Snap On, Sears,
door panel is easy bro.
1) pop all the snap in fastners you see around the door, underside and all
2) pop out the piece with thehandle that you pull to shut the door, pop it from the top first and then pull it, it just pops out.
3) take out the screws holding the power window switch and pop the harness for the mirrors loose.
4) youll see a couple screws there where you popped the door piece out, take them out.
5) pop out the piece where thw inside door handle is.
6) now youll be bale to pull it off, pull from the bottom, itll pop out. just work with it.
7) itll go back together the same way you took it apart.
holla back if you need anything...
Sep 25, 2015 06:58 PM
