Transmission Fluid
Transmission Fluid
What kind of fliud should I use on a T5 transmission. I just bought a WC T5 and I dont know what kind of fluid I should use for it. Chilton's says
- All 4-speed and 5-speed manual transmissions except for the T5OD - SAE 85W/90 gear oil.
- T5OD 5-speed - Dexron II or Mercon ATF
SAE 85W/90 gear oil may be used in the T5OD transmission in very warm climates or if gear/bearing noise is excessive.
I'm guessing the T5 trans I picked up is a T5OD and I live in Illinois, so should i use the gear oil or the ATF?
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
