trick flow upper end kit
RE: trick flow upper end kit
that is for valve springs, but .540 is about max with them.
ORIGINAL: r.barn
It's all in how much lift your cam is making, again this is direct quote off TrickFlow web site
" Maximum camshaft lift with factory flat top pistons: Twisted Wedge: .540" lift; Track Heat: .600" lift "
Just use their Stage 1 cam and you're fine, it will even leave you a little room for vavle float.
ORIGINAL: laserred9550
ok so who's correct? AdderMk2 or r.barn?
thier vavles are at a different angle so thier head with 2.02 valve cam be used without notching the pistons..still always check piston/valve clearance....if you were ever to buy new piston then the reverse dome works alsum with those heads
Dragonus18
09-09-2015 01:21 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
