Replacing front springs
RE: Replacing front springs
ORIGINAL: PRO50SC
Yup, a floor jack, big pry bar and a second guy would help.
lol!!!!!!! yea the fox front suspension is fun. ford has a special spring compressor designed to fit up the center of the spring. i think its like $500 box. yea so F@#% that. I made a tool from a long 5/8" bolt and some steel stock that worked. Just remember to wrop the new springs with electrical tape or something so they dont get beat up. Its gunna take some creativity to get em in and out without a tool.
doing front springs is actually really easy, make sure you disconnect your tie rod end so you can allow the control arm more room to travel. I used a large friend to help, i had him step down on the control arm while I pushed the spring in place... start the top first
ORIGINAL: AdderMk2
You can do it with a prybay, but maybe some external spring compressers would do the trick better.
sould be about the same... and actually.... foxes have shorter springs than SN-95s... so it should be MUCH easier for you guys (and dont forget... my car has the same front subframe and control arms that yours does)
Its really easy, jack under control arm, disconnect strut, tie rod and so forth. Use a chain to hold the spring to the top of the spring perch, let the jack down lowering the bottom control arm. unbolt chain take spring off. Using the chain is great so you have no fear when you let the control arm out that the spring is gonna fly out. Saw a guy die taking out Nova springs at a local dirt oval track, hit him in the chest and that was that.
