Poly motor mounts?
RE: Poly motor mounts?
ORIGINAL: 93foxgt
Pretty straight forward install right? Just put a 2x4 under the oil pan, undo the 2 bolts per bushing, then put a 2x4 under the oil pan and lift the engine, right?
i'm just telling you what i was told. he said as soon as he took the poly trans mount off and replaced it with an OEM, he quit having problems. maybe its just him. i dunno. he is kinda goofy.
That 2x4 probably won't break right? Also, would you do it with a crappy 2000lb autozone hydraulic floor jack? (I know the engine is much lighter than 2k lbs, but still)
And is there any place in particular to put the 2x4 under?
ORIGINAL: 93foxgt
here's and article 5.0 did Motor Mount Article
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
