combo suggestion
combo suggestion
so I got a set of trickflow's twisted wedge heads for cheap... I want to also do a cam and intake swap at the same time. What cam and intake do you suggest running? the engine is pretty much stock as of now wit 89k
I was thinkg about the RPMII since I have heard some pretty good stuff about it and the E303 cam, but I have heard there are better cams with bigger gains out there. I basically want the most power possible and still staying emissions legal. thanks
RE: combo suggestion
the heads are brand new still in the box! I originally wanted to go wit some AFR's but I couldn't pass up this deal. So it looks like the trick flow intake and stage 1 cam... what intake do you think the street heat or the track heat? The differance is just the RPM band that it makes power at right? Also will I lose any torque with this set up? Thanks for the help guys
Get an account at fordmuscle.com to see some back to back dyno tests. Basically the two are pretty close (intake manifolds).
The FRPP cams aren't the best anymore; go with the whole Trick Flow setup, I'd say so you are sure about the combination working together well.
Mark
Mark
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
