vacuum line?
RE: vacuum line?
What intake? New or used?
I got a used TFS street heat and it had an extra hose as well. Some people run it to a PCV inlet on one of the valve covers and plug the one going from the TB to the oil filler tube on the valve cover. If you have different valve covers that don't have that filler tube [like my FRPP tall covers] then you have to use a grommet and a PCV valve to fit from an auto parts store.
RE: vacuum line?
its a ford explorer intake. mostly all hooks up the same. but i had to relocate this one vacuum line to the upper part like where the pcv hooks up before it gos to the lower intake. the explorer intake had an extra one so i just put it there. now i just dont know where it gos after that.
RE: vacuum line?
I'm not sure what the connections are on the explorer....they may not be the same. If that's the case, you may be okay just plugging the extras. Also, the intakes differ before 1997.5 and after. After didn't have the EGR stuff on it and I think they relocated the ACT sensor by the MAF.....
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
