I need help finding a good blow off valve for my 92 mustang. i'm not really sure what to get so i'm looking for some options. I going to run 7 psi . Any help would be great!
also is it an auto or a manual trans, if its an auto and your not running that large of a turbo, especialy at 7 PSI you dont even need a BOV- spend the 200$ on somthing else ive run my car at 30 pounds of boost with a super 70 ball bearing with no blow off and havent hurt it yet. when you let off fast after a hard acceloration- it will give you some compressor surge, but it wont hurt anything
I have 1 5/8 primaries, 2 1/2 cross over, 3 downpipe and wastegate 38 mm. As for the tubro size i'm not sure because im still waitng for it show up. (ebay)
if the supercharger im getting can go up to 9 psi on a stock engine without needing a blow off valve and if my friends turbo is running 8 without one on a stock 4 banger, you will be fine.
