what kind of ranny fluid, and oil
I'd like to throw some royal purple tranny fluid in, will the Dexron III/Mercon work in my stock t5?
I can't remember if it's supposed to have Mercon V in it or not, or what I need... lend me a hand!
I'm curious what kind of oil you guys run? I don't think I'm going synthetic yet, but I'd like to know what weight you guys run. It will only see the summer weather.
RE: what kind of ranny fluid, and oil
ORIGINAL: ricepatrol
synthetic is a waste of money, unless you start using it when the engine is brand new. even if its only got 5000 miles on it, there's no point in running synthetic -- as the regular oil is already laced on all of the moving parts and such
i live in louisiana its always hot down here, currently im running 5w-30 but when i change the oil this weekend im going to put straight 30 in, pennzoil or mobil is the only oil i use, as far as transmission fluid, i have an aod and i have no clue whats in it, but whats good to put in it? before i bought the car about 2-3k miles ago, he had the tranny serviced right before he sold it to me, so no clue.
Straight 30 is wayyyy to thick... If you break down the numbers 10-30...5-30.... The oil viscosity is around 30 when the car is cold, once it warms up the viscosity is around 5 or 10 depending on the oil... I would definetly not put straight 30 in the car... IMHO
BTW, for those concerned about oil ratings, synthetic flows so much easier that a 5-20 regular is about equal to 10-40 synthetic. Additionally, you can expect a 5 HP gain just by switching to synthetic.
So the Dexron III/Mercon will work then, great.
What weight oil do you guys run in your motor, non-synthetic? I think I've been using 5-30 but I don't remember, if I should be using something else, I'd like to know what to get.
Been running cars a long time, been using synthetic weights in all my performance vehicles. For summer I usally switch to a 10w-40, winter months usually a 5w-30. Dexron/Mercon III is the only oil to use in your T-5 tranny. Although, I recently did a clutch swap on a 93 Mustang that had been running 80-90w gear oil. Owner was wondering why the tranny shifted funny Got it all straightened out and now running the correct fluid.
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
