How to remove factory rev limiter?
RE: How to remove factory rev limiter?
ok just trying to weigh out my options. where is a good website that does ecu burning. I may go that option and i have another question about the tweecer. If you get the rt version with the datalogger does it show what the o2 is reading so u can see if ur lean or not. I know that a wideband is the best way to go, but i just want something to get me close
cool deal. i think that is what im going to go with. is it very hard to use. my eclipse had a similar thing called a dsmlink that did the same sort of thing. it was real easy though. you could just tell it what size injectors you had and it would get it close. then you could fine tune it later.
jwog666
12-27-2021 08:09 PM
