speedometer cable
Old May 22, 2006 | 12:48 AM
sgt_pepper17's Avatar
sgt_pepper17
Default speedometer cable
Hey,
My speedometer has never worked. The speedometer cable is melted probably from the exhaust. I checked the gear, and it's fine. The cable has a little wiring harness on it on the transmission side. The car does not have cruise control and it is a 1884 GT with a 302. Two questions:
What is the wiring harness for?
Can anyone tell me where to start my search for the cause of my speedo not working?
Thanks
Old May 22, 2006 | 01:35 AM
12Pack's Avatar
12Pack
Default RE: speedometer cable
Did you pull the speedo cluster out and see if everything is okay?
Old May 22, 2006 | 01:36 AM
TENGRAM's Avatar
TENGRAM
ORIGINAL: sgt_pepper17
Hey,
Thanks
speed sensor wiring connects to the speedo cable(not sure that the 84 has this)
gear switch hooks to the tranny on top i think (manuals and autos have a version of this one)
reverse light switch also hooks up to tranny, this one on the side
hope this helps
Old May 22, 2006 | 01:39 AM
BlackMustang02GT's Avatar
BlackMustang02GT
i never knew the ford made mustangs in 1884 maby thats why its not working?
Old May 22, 2006 | 07:33 PM
sgt_pepper17
hey buddy [sm=smiley35.gif]. I made a typo. i didn't know they had speed sensor. what's this for? an electric governer? I'm running a points dizzy with a pertronix ignitor, so that shouldn't be an issue. I had my gauge cluster out but i'm not sure what to look for.
Old May 23, 2006 | 12:22 AM
TENGRAM's Avatar
TENGRAM
cruise control mainly but the ecm also uses it for some air/fuel calculations and other functions,
but you dont have efi...do you?
also, as you may already know, the gear switch works in conjunction with the clutch safety switch to prevent starting the car when in gear and clutch not depressed.
articman
Jun 21, 2018 11:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
