SFC
SFC
They're all basically the same, with the majority being weld on, and some being bolt on. I would go with the weld on sfc's as you don't get "bolt hole elongation", and it's a stiffer install. If you have a convertible, do some research because some will not fit convertibles. Most bolt on's can also be welded.
