cleaned engine now probs
i just cleaned the engine on my stang. i used engine degreaser and a high pressure sprayer but made sure not to get too close to vacuum lines and alot of electical connections on the motor. i started the car up afterwards and it ran fine (moved it underneath a tree) i let it sit for a couple hours went to restart it and it didnt wanna start without turning the idle up a little bit. i finally got it started and it runs fine as long as its idleing or if you slowly give it throttle. but if you chop it or give it a bit too much throttle it'll start breaking up and sometimes backfire.
RE: cleaned engine now probs
i have the exact same problem on my 88 lx and am convinced the water is getting in a wiring harness somewhere and causing problems until the water dries out. i've since not sprayed down my engine compartment 'cause i can't find the problem, but i know exactly what you are experiencing
Here's an old trick... take some silicone spray and spray it under the distributer cap... don't saturate it, but a few good blasts is okay... that'll get the water out and prevent water from causeing problems next time....
09-01-2015 08:16 PM
