pic needed spark wire routing w/ moroso
I bought a spark plug routing it from moroso. Its the usual valve cover bolt style, with tall posts where you can mount 1-2-3 or 4 spark plug holders.
I'm not really where to mount which holders and on which valve cover bolts.]
can someone put up a pic?
also, do i need to remove the valve cover bolts to install these? Can I remove the bolts one at a time, or all at once?
Do i need a new valve cover gasket if i do this?
thanks
thanks
RE: pic needed spark wire routing w/ moroso
Don't know anything about the routing, but if you remove one bolt at a time and then replace them one at a time, before removing another, you should be fine. Just make up your own routing that suits you best. Nothing is really particular when it comes to that stuff.
Ltd10th03cobra
09-01-2005 05:06 PM
