408 in a 95
408 in a 95
I am considering buying a 351W and stroking it to 408 and putting it in a 95 GT while retaining the EFI.
WIll 351W will bolt right up to the 5.0 tranny?
Will i be able to use the bolt-ons from the 5.0 on the 351W?
And i heard I had to get a new hood because of clearance, is this true? any recomendations?
RE: 408 in a 95
Wow, that's quite a swap. [:-] You're going to need to change a lot, but yeah the transmission will bolt up to the 351 block. It would be a bad idea though because you'll rip that transmission to pieces with that much more power. The T5 is barely adequate enough to handle the stock 5.0. You will also have to get a 351 EFI lower intake because the 5.0 lower intake isn't wide enough to fit between the 351 heads.
RE: 408 in a 95
I have converted to a 351 in my 89, if you want to know detailed steps to follow that will make it easier e mail me and I will let you know what will work and what wont. The Trick Flow intake for the 351 in Killer, I wouldnt go any other way, Dave
mustangdave357@hotmail.com
RE: 408 in a 95
try www.lentechautomatics.com they do heavy duty AOD's and can make one to take the power of a 351 I'm sure and you'll have the advantage of the overdrive too. or else get a C-6 tranny from anyone of the many transmission companies out there. I bought an extreme AOD tranny from Art Carr Performance for my racer and it is a killer with a full manual valve body and no overdrive. don't have any experience with current generation 5 speeds, so I can't say anything about a manual tranny.
RE: 408 in a 95
If you want a manual, Tremec just released 2 new models of the TKO, the TKO-500 and TKO-600, built to handle 500 ft. lbs. of torque and 600 ft. lbs. of torque respectively. They cost about $1500-$1600 everywhere I've looked. Those should be enough to handle your engine, unless you plan on pushing the envelope even further.
RE: 408 in a 95
or for around 1000 you can take the T-5 and put in a G-Force kit with new gears that will handle 600 hp and 500 lbs of torque. The TKO only handles like 400 hp and is alot more money. But what you decide is up to you.
