Loose Pilot Shaft
Loose Pilot Shaft
I bought a transmission recently, and the 30 day warranty is up. The only thing thats wrong with it is the pilot shaft. Its a little loose and when you spin the clutch, it makes a semi-loud grinding noise. It seems like this can be fixed pretty easily, maybe a few bearings inside of the transmission, or something like that. Am I right on that? Also, about how much do you think a transmission place would charge to do something like that?
Thanks
Thanks
RE: Loose Pilot Shaft
are you talking about the input shaft, if you are then it is normal, youd be suprised at how much it will move up and down. probably a quarter inch either way. i thought something was wrong with the 4 cylinder tranny i put on my 5.0l but its normal.
I attached a picture of what I'm talking about.
Thats also another thing I wanted to ask about. I have a 4 and 8 cylinder tranny. I bought the 8 cylinder and have no clue how it does. I've had the 4 cylinder one since I've bought my car. I'm in the process of doing the conversion right now and I know the 4 cyl. performs well. Although I didn't know how it would do controlling all of the power the v8 put out. Is this cool? How would I get the 4 cyl one to fit. Someone told me to put copper tube over the end of it to make it fit. But I think that would give out under all of the spinning it would be doing. I think I can get a new bushing to make it fit and that seems safer. Although at the time I didn't know how the 4 cyl. would hold up under a v8
So what do you think? Get the v8 trans fixed, or mount up the 4 cyl. Pros? Cons?
[IMG]local://upfiles/38255/2880E02415DF413199CBA282B1B061C1.jpg[/IMG]
that is just the alignment tool to lign the clutch up so the input shaft slides in properly. i coudlnt tell you how long the 4 cylinder tranny will last, iv had mine in a month and im fairly hard on it, 3rd and 5th are on a planetary gear so if you are hard on them they will break i never powershift third. my car has been runin like **** lately so thats prolonging the tranny lol. first gear is absolutely useless. the 4 cylinder tranny bolts up you just pop the round thing out of the middle of the v8 bellhousing and bolt the bellhousing onto the 4 cylinder tranny. nothign else dont even need to change driveshaft. if you are going to put it in i would advise having an extra just incase. i dont but im a rebel
there alot tougher then people think.
So, you're saying it doesn't matter if that moves?
Although it makes a loud noise if you spin the clutch on it. If you spin the clutch on the 4 cylinder it doesn't make any noise.
You cannot move the shaft on the 4 cylinder....I'm extremely confused. my apologies
bradleyb
11-27-2015 07:50 PM
