got the radiator in finally!
#21
RE: why wont my radiator go in?
yea i canned it. do i need it because i kept the brace to plug the main harness in but the small pulg that went to the tank was left off. will it be ok?
#22
No, you'll need the overflow. When your system gets hot, the fluid will expand and it needs a place to go (conversely, it needs to be sucked back in when it cools down). The overflow has to be there. You can't just let it leak out onto the ground and under your tires.
I was looking for the canton overflow I saw but I can't find it -- not even on their site.
Edit - I've been meaning to ask you -- what is that pictured in your avatar?
- Jeff
- Jeff
#25
cool. ill try to slide err in tomorrow. i wasnt really thinking i dont guess. it would eventually run out all the water if i didnt use it huh?[:@] duhhh!!
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
