PCV valve on cobra intake
does anyone know if you need to take the upper manifold off to change the PCV valve with the cobra intake manifold? The PCV valve is in the back of the manifold, towards the cab, correct? Should I buy the whole PCV kit or just a new valve from 50resto.com?
RE: PCV valve on cobra intake
No you do not have to remove the upper...Its a little tight but very fesable, you should only need the valve unless your groument in the intake is cracked or ripped..
11-10-2015 11:39 AM
TfcCDR
09-14-2015 12:08 PM
