Specs
RE: Specs
Dont know how good a Haynes manual is but a good manul is the ford one. Its a bit pricey but it gives you everything. Probably some that the haynes doesnt give. There is 5 full pages of specs on the 5.0 in the Ford manual. Only bad thing about the manual is thats its a bit pricey. You can find some used ones cheap on ebay.
RE: Specs
i dont have torque specs but i got the engine specs ill paste em from my cardomain
1987-1993
8-Cylinder, 90V ° Overhead Valve
EEC-IV Electronic Engine Controls
5.0 Liters (302)
225 hp @ 4200 RPM
300 ft/lbs @ 3000 RPM
9.0:1 Compression Ratio
4.0" X 3.0" Bore & Stroke
5 Main Bearings
Hydraulic Valve Lifters
Sequential Multi-Port Electronic Fuel Injection
Unleaded Fuel
1987-1993
5.0 Liters (302)
225 hp @ 4200 RPM
5 Main Bearings
Unleaded Fuel
RE: Specs
Cavedawg
09-17-2015 09:51 AM
