I GOT MY CAR BACK!!!!!!!!!!!!
omg there is such a difference in what it is now compared to waht it use to be. but now i have to put 250miles of break in time on it while it surges all over the place it sucks. that and the alignment is off now from putting the tublar front end in. It needs to be tuned so bad to keep it from surging so after break in time i can actually get it tuned and then mash the gas. I CAN"T WAIT!!!! also u should hear the thump from the cam sounds amazing!!!! anyways heres the new stuff on it
but tell me what u think about it here is what all was done to it:
New MODS
347 stroker fully forged
Balanced rotating assembly
lunati nitrous cam
sct chip tune
zex 125 shot
ford racing lifters
1.6 roller rockers
comp cams hardened pushrods
ac delete
trickflow track heat
3/8 intake spacer
bbk tb 70mm
C&L 76mm kit with MAS
reworked e7's have been ported 3 angle valve job milled 40 185 160 valve's
dual valve springs
double roller timing chain
#30 injectors
msd 6al box
msd rpm selector
msd bronze dizzy gear
zex purge kit
zex rapid fire kit
professional products harmonic balancer
arp head bolts and studs
line honed
suspension: new mods
D&D K-Member
D&D Coilovers (150lbs spring rate)
D&D tublar a-arms
BBK caster camber plates
battery relocated to trunk
what do u think?
New MODS
lunati nitrous cam
sct chip tune
zex 125 shot
ford racing lifters
1.6 roller rockers
ac delete
3/8 intake spacer
bbk tb 70mm
dual valve springs
#30 injectors
msd 6al box
msd rpm selector
zex purge kit
zex rapid fire kit
line honed
D&D K-Member
D&D tublar a-arms
what do u think?
RE: I GOT MY CAR BACK!!!!!!!!!!!!
man that sounds like a nice setup. definetly put some vids when you get it broke in. speaking of which, what are you doing on here. get out there and break that thing in
actually yea it is running a little rich but i have been driving it alot already but it gets kinda annoying with all of the surging but its still not as bad as i expected it would be but it still has its moments. but i have pretty much used 20bucks on gas today alone so i am hoping to get it tuned by this coming weekend....wish me luck i am shooting for 300rwhp on motor alone
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
'stangdude
08-12-2015 01:27 PM
